Old 07-24-2011, 01:51 AM   #1
Default Dual hitch receiver
I'm thinking about using a dual hitch receiver that I have so that I can have the bike rack and a small cargo rack on the hitch at the same time.
If you have any experience with this or any advice to offer please let me know. I don't want to exceed any component rating.
My '97 GMC Savana Diesel specs show the max tongue weight as 750 lbs.
The Class V has Gross Load Capacity Tongue Weight of 1500 lbs.
The Roadmaster dual hitch receiver has a capacity of 400 lbs.tongue weight.
So all of that means that I now have a max tongue weight of 400 lbs. to work with.
I purchased the dual hitch receiver so that I could carry the bikes and still tow my car with my Class C RV. That is what Roadmaster makes this for. Instead of towing with my Class B I think a small cargo rack would be useful.
I like that I can open one of the rear doors with the bike rack on.
I placed a piece of old plywood on the Lund DIY cargo brackets to get an idea of what would fit.
I might carry a Honda EU2000i (L x W x H) 20.1" x 11.4" x 16.7" weight 46lb dry.
I'd most likely use 1/8th thick diamond pattern aluminum sheet for the cargo rack platform. The two bikes, bike rack and cargo rack would probably weigh 100 lbs. So I think that with other gear on the cargo rack maybe that would double to 200 lbs. I think that should be safe.
Any thoughts?
Old 08-14-2011, 07:18 PM   #2
Default Re: Dual hitch receiver
The dual hitch receiver setup works ok. I added a couple of Plano brand boxes. They seem weather tight. They are through bolted to the platform. 6 bolts on the large box and 4 bolts hold the small box and I added a bungy cord. The whole dual hitch receiver setup does have more play than I'd like. I can open one rear door when it is setup as in the photo.
and I can load and unload it all in my garage.
I don't really like it though. I'd rather travel with nothing on back. It always comes down to what to do with the bikes................
Lots of small rigs have something on back.
Old 08-15-2011, 04:56 AM   #3
g1g
I have never seen a hitch setup like that. It looks interesting but I have had thoughts of a "wheeless trailor" if I ever get the chance for extended travels. I also had the thought if I were to cary a bike or scooter that I would have a bracket just extend from the basic pad straight up instead of going into another reciever. This way would be slightly simpler and save a few pounds.
