Testing Phase
I was suspicious that the survey could not test the unit, as it was; “…too cold in Mass to run it.” Accepting that, knowing it was 14 years old it might need some work. I tried to test the unit in situ. All I got was a “Relay” like click. Study of the inter-web yielded a number of approaches; SoftStart, replace capacitor, replace the unit, etc.
Those that replaced their units all raved about the new technology, improved efficiency, lower noise, and other favorable characteristics.
I removed the unit, took part of the day, using a scaffold, and a helping neighbor got it down. Before it goes to the scrap heap, I want to give it a go. The wiring diagram is for an earlier unit, and I’m trying to figure out which wires (on the thermostat lead) I need to connect to effect a turn on.
Looks like the suspicious ones I’ve identified. Any thoughts, before I head off shopping for a replacement?
Thanks in advance.
Cheers - Jim
