Old 10-15-2013, 05:51 PM   #1
Default Digital Wireless Backup Camera Installation
This forum is "hands-on" so I thought I would post this here.
Here are pictures of the digital wireless camera I installed (though Yahoo jumbled them out of order):
http://groups.yahoo.com/neo/groups/road ... 1431831314
So far I am happy with the camera. I get no interference that others have complained about with analog wireless cameras.
The install wasn't too bad, especially since I did not have to run a camera cable from the camera to the monitor or monitor box. Installing the transmitter in the right rear brake/turn signal light area took some work to route the cable there.
I made a monitor mount from a thin sheet of RV aluminum siding. I used 4 small socket head cap screws threaded into the aluminum to attach the monitor (see the picture). The camera mount is made from thin aluminum also.
I wired the camera to the parking lights so I can turn it on when I want. You can turn the monitor off if you don't want the camera on at night.
The camera is not high resolution nor does it have a large field of view, but it is sufficient to make sure I am not going to run into anything backing up. It has proven handy to keep an eye on my boat trailer when towing.
The unit is made by YADA. I got it at Pep Boys but it is also available on Amazon.
Pete
2006 RT210P
Old 10-15-2013, 06:10 PM   #2
Default Re: Digital Wireless Backup Camera Installation
Looks good Pete.
I could put a copy of the photos here if you don't mind. I think only members of that Yahoo Group can see them.
Old 10-16-2013, 12:20 AM   #3
Looks good Pete.
Yes that is OK if you want to put them here.
Pete
2006 RT210P
Old 10-16-2013, 02:03 PM   #4
These are smaller photos - larger images are available at the link Pete posted:
