Old 02-08-2021, 11:34 PM   #1
Default Cheap under body replacement propane tank?
I've been reading the threads on replacing the propane tank under the rear of my 98C200V. Options seem to be in the $600 + range. Do you suppose I could make this tank work for $125? It's a 20lb horizontal mount Flame King.
File Type: jpg Screenshot 2021-02-08 at 4.46.43 PM.jpg (99.3 KB, 36 views)
KaptainK is offline   Reply With Quote
Old 02-08-2021, 11:39 PM   #2
Looking at it now, it may hang too low (might be more roundish than original). My unit had the tank removed by PO. I don't know what the dimensions are of the original.
Old 02-10-2021, 05:06 AM   #3
Doesn’t the Model you have have an Expiration or some Inspection Date? The Installed B Tanks do not require that.
Ron J. Moore
'15 RT210P
Old 02-10-2021, 01:40 PM   #4
The PO had removed the tank.
Old 02-10-2021, 06:34 PM   #5
Call Roadtrek Phone: 519-745-1160 Toll Free: 888-ROADTREK (762-3873) and ask them what tank was installed on you RT. Go over to Facebook's Good Old Roadtrek and ask if anyone might have a build sheet for a similiar Roadtrek model. The build sheet will tell you the manufacturer and model of the tank. Manchester tank built the one one my 2008 and they no longer supply them. Roadtrek sold much of their vintage stock to two different places, one in Ontario and one in Mississippi. Can't remember the names of either, but a search here on on the Facebook sites should find them. The place in Mississippi had a tank that would fit my 2008 and wanted over a $1200 for it. Maybe best to find someone who is parting one out.
You need to put the right one on for it to bolt up properly - and you can't go welding on them to modify them to fit!
Found the link for the Canadian company that purchased RT parts: https://www.mobiliferv.ca/rv-parts/roadtrek/?page=1
If I find the other company I post it here. Oh, you might try "Class B RV PARTS and Accessories-Buy, Sell, Trade" on Facebook too!
2008 Roadtrek 210V
Formerly:
Toyota Sunrader
Tiffin Allegro
Foretravel U225
Old 02-11-2021, 07:11 PM   #6
Take a look at the VW propane tanks from Gowesty.com Unfortunately they are pricey but they are under mount tanks and may give you the clearance you need.
https://www.gowesty.com/search-resul...phrase=Propane
Ken
Old 02-14-2021, 09:58 PM   #7
Looks to me like the mounts are on the wrong side - after mounting the vavle would be on the bottom. That is not what you are looking for AT ALL.
Joint the Classic RT form on Facebook. LOTS of GOOD information there.
99RT190P - so my tank detail may or may not be correct.
StephenP is offline   Reply With Quote
