Old 05-13-2023, 11:03 PM   #1
Default Cab overhead shelf options.
I decided to add a cabin overhead shelf for my NCV3 Sprinter van. Options include:
1. White Top Adventure, aluminum, powder coated has option for front or rear curtain rack or rod. https://www.whitetopadventures.com/....eadliner-shelf
2. RB Components Raised Overhead shelf, aluminum, powder coated, https://rbcomponents.com/products/sp...nt=42642754064
3. Radius outfitter https://radiusoutfitters.com/produc....iABEgJr6PD_BwE
4. My design with Radius Outfitter like cut-out raised to access factory shelves which I use often.
I am 6’2” after spine surgery so ingress and egress from the van to the driver seat is important. Ideal for me would be a Radius Outfitter shelf with the middle cutout at RB’s raised height.
I sent an email to Radius Outfitters asking if they plan to introduce their shelf allowing access to factory shelves.
Please share your thoughts.
Old 05-18-2023, 06:06 PM   #2
Texasnielsen's Avatar
Default Head banging decision
My shelf was a constant head banger when we first purchased the van. Once being a significant neck/spine jolter!
Being this would be a new addition to your van and you’ve likely developed some unconscious habits concerning entry to the seat from the cabin I would opt for the shelf that would proved the best alternative of space AND accessibility.
There are options, DIY and overpriced aftermath, for solutions to pad that headbump area. Depends on how quickly we learn to duck sooner I guess as to what works for each of us.
Texasnielsen is offline   Reply With Quote
Old 05-18-2023, 07:18 PM   #3
Thank you for your post. I am currently thinking about the following options:
1. Copy this design - https://sprinter-source.com/forums/i.../#post-1334727
2. Design a shelf from 1” 80/20 or ˝” tent poles and a cargo net. Shelf would be mounted at a steep angle with rear edge at 6-8” from the headliner max and front lowest possible but allowing full access to the factory overhead shelves.
Old 11-02-2023, 10:53 PM   #4
Change of plans. I purchased Shuksan"s cab shelf for our 2013 Sprinter. Why I decided on Shuksan:
1. It is mounted high allowing full access to over sun visor pockets. In discussion with the shop owner, he shared that full utilization of these pockets was his design goal.
2. Strong construction with double bend of rear enforcement
3. Rounded corners in case of head hit
4. Front L-track will allow a few hooks
5. Rear curtain bar which could be used for towels.
The shelf was extremely well packed, it fits the headliner contour very well, overall fit and finish excellent.
I regret that I didn’t add this shelf earlier, was too concerned about ingress and egress. I mounted the shelf yesterday and tested how easy was to get in and out, no issue.
I will add pictures later.
Old 11-03-2023, 12:21 AM   #5
Boxster1971's Avatar
Great choice! I installed the same one in my new Sprinter last week. I researched a number of these shelves and like you found the Shuksan to be the best for my use.
Old 11-03-2023, 12:52 AM   #6
Does the Sprinter have side airbags that these shelves will interfere with? I was going to add one to our Transit but they would mess with the airbag deployment.
Punkinhead is offline   Reply With Quote
Old 11-03-2023, 01:05 AM   #7
Side airbags are up to top of side windows, about 8" below a shelf. Scroll down to safety page to see the airbags picture. https://www.outsideonline.com/outdoo...cient-vanagon/
Old 11-03-2023, 02:40 AM   #8
We have the overhead cab shelf. Duffle bags with clothes fit nicely because they can be squished down to fit the curvature of the ceiling.
File Type: jpeg Mies with Turned around Seats & Tables.jpeg (328.3 KB, 11 views)
Old 11-03-2023, 05:33 AM   #9
Are these LED lights?
File Type: jpeg Mies with Turned around Seats & Tables.jpeg (379.6 KB, 4 views)
Old 11-03-2023, 05:15 PM   #10
Yes. All the lights are LED. That pink light at the baseboards can be any color with a dial. That is just a thing ARV does I guess for effect. There are panels of six touch buttons everywhere including each bunk bed that can control all the lighting and the water pump at the Silverleaf control panel, kitchen counter and bathroom.
Old 12-13-2023, 11:25 PM   #11
Overhead shelf is finished. I added the curtain for short nights, the windshield and front windows curtain take more time to attach.
