Old 02-03-2015, 04:51 PM   #1
Default 200-watt solar panel installation
I recently added 200 watt solar panel on my Agile, if anyone interested of doing the same you can see the full install/build with pictures here: http://roadtreklife.blogspot.com/201...l-install.html. Thanks for looking.
Roadtrek Agile SS: Roadtrek Mods.
https://i42.tinypic.com/dwrjpi.gif
RT.SS is offline   Reply With Quote
Old 02-03-2015, 06:31 PM   #2
Default Re: 200-watt solar panel installation
That is really well done
Old 02-05-2015, 07:29 PM   #3
wincrasher's Avatar
Very nice! You have an issues with the roof air conditioner casting a shadow on the panel?
2019 Winnebago Travato GL
Old 02-06-2015, 12:38 AM   #4
Something is always going to cast a shadow from somewhere. The best way to combat this is put as much solar as you can fit and afford unless you want to haul around portable panels and cable.
Old 02-06-2015, 12:40 AM   #5
I have a question about your tv antenna. I saw them on sale at CW and was wondering if they work good retrofitted to the old batwing.
Old 02-06-2015, 01:08 AM   #6
I had the same question. If they work well it would give me room for a third 100 watt panel.
Old 02-06-2015, 03:18 PM   #7
The AC does cast shadow on the panels depending on time of day and position of the RV in relative to the sun, mostly only when sun is low on the horizon like early morning or late afternoon.
The Winegard Rayzr antenna does work well in my location, I get more channels compared to the batwing, but that really depends on your location and signal strength of the channels. The Rayzr has a wider field of view while the batwing has narrower field of view which is good for picking up distant channels.
Old 04-13-2016, 05:07 AM   #8
briancummings's Avatar
You would be very surprised to see how much amperage production falls with very little shadowing....One might think, 50% shadow equals 50% less amperage, but one would be very wrong....you can lose 50% amperage with as little as 5-10% of the panel surface in shadow....just an FYI.
briancummings is offline   Reply With Quote
