Old 02-25-2016, 07:56 PM   #1
Default 1990 Roadtrek Black/Grey Water Exhaust Leak
I got a leak at multiple areas, one being the valve to the tank which I see I can order off Amazon and replace, also I have leaks somewhere in the body width long pipe which is inside a metal pipe that has rotted considerable at the opening end. Is it possible to find a metal pipe replacement somewhere or should I even worry about that? I could conceivably get some of that black irrigation pipe from Home Depot and remove the metal as I don't see high centering this thing and even if so the cost of black pipe is nothing I'm sure compared to that metal shroud. Does debris come up at a rate which I need that outer metal pipe? Thanks for your help!
J_Doc is offline   Reply With Quote
Old 02-26-2016, 02:00 AM   #2
Bruceper's Avatar
I would go with PVC pipe but I'd still keep the shroud just in case. The worst that could happen is the PVC breaks and you have a spill somewhere and get fined for it.
You could rework the shroud though, it doesn't need to go completely around the pipe if that makes it easier.
Old 03-01-2016, 04:51 AM   #3
Johnny R's Avatar
Sometimes it is not a leaky valve, but a piece of crap or toilet paper that is jammed in there. I'd be tempted to try a good flush before ordering a valve.
Johnny R
Johnny R is offline   Reply With Quote
Old 03-01-2016, 04:10 PM   #4
Considering the condition of a lot of the other items on this fixer upper I preemptively ordered some valves as one of them is real loose feeling at the least but I'll check it out when I drop it down to see if it's just a blockage. The main pipe is definitely in need of some service so wont be a total waste. I got some waste water treatment on Amazon a bunch of people say is good at breaking down regular toilet paper is that not the case??
Old 03-02-2016, 05:40 PM   #5
Johnny R's Avatar
I use biodegradable toilet paper which is made for chemical toilets
Johnny R
Old 03-04-2016, 09:14 PM   #6
I cobbled together a new system using 4" pvc Bell mouthed drain pipe with a sheet metal heat shield and common hardware for my 92D190V it has held up for 15k++ miles, I also fabricated a better support at the end of the pipe
jeomelia is offline   Reply With Quote
