Old 05-18-2024, 10:01 PM   #1
Default Winnebago Roam furnace question
New to RVs, just picked up a Winnebago Roam, and trying out all of the functions. I tried the furnace, gas, and ended up with error code 13. This is a Elwell furnace. Failed to light after trying to start twice. My question is, does anyone know if there is a fuel shut off valve? I looked at the manual, didn’t find anything of the such. Any help would be great.
SEACA88 is offline   Reply With Quote
Old 05-19-2024, 04:04 AM   #2
You have to have at least 1/4 tank of fuel for that heater to get fuel. Beyond that you will have to chase the fuel line to the tank. Finding the heater fuel pump and check for operation may help.
You may just have air in the line. Try it several times. Maybe check the owner’s manual for fuel line priming. I don’t have an Elwell heater but I did find that error code 13 means no fuel.
Here is the manual which I assume you have. Page 17.
https://elwellcorp.com/wp-content/up...nual-6x8.5.pdf
