Old 12-18-2018, 03:50 PM   #1
Default Water stains around Roadtrek windows?
Hello everyone. First post here.
I'm looking to purchase a class B or a converted van, but when I look at Roadtreks, I notice quite a few of them have moisture around the three skylight windows. Has anyone else noticed if these are normal or if I should avoid them altogether? They are mostly between 2002-2005, the ones I've seen. I saw a "newer" 2007 210 that did not have this issue. Biggest concern is mold.
superheroego is offline   Reply With Quote
Old 12-19-2018, 03:52 PM   #2
Windows can and do leak. The older the van, the more likely these windows have needed work, and not received it. Personally I would avoid buying any vehicle with visible water damage because you never know what you can't see.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Old 12-23-2018, 07:13 PM   #3
We dont have that issue on our 2008.
Max58 is offline   Reply With Quote
Old 12-23-2018, 10:56 PM   #4
my 2005 P210 has water stains around the skylight windows.
ValofNY is offline   Reply With Quote
Old 12-24-2018, 12:13 AM   #5
Default 190 Ranger
The Roadwork Ranger has fake windows, i.e. no leaks or mold ... lol.
The original 2012 Ranger, built on a 3/4 ton 2500 chevy express chassis, was designed as a scaled down no frills cheaper version of the 190 Poplar A "190/Ranger" may be worth looking at if it falls inside your budget and you can find one. They are similar in content to a 190 Poplar but with no drop down floor (shower area is contained behind hall door) and have vinyl floors instead of carpets. I expect that there aren't very many of them.
Merry Christmas from Ottawa Canada
Sensfan is offline   Reply With Quote
conversion, roadtrek
