05-13-2016, 03:07 AM
Used E-Trek?
Hi all,
I have a line on a good deal on a used 2014.5 Roadtrek E-Trek that I'm considering. My mind's far from made up, but I thought I'd seek the wisdom of the forum.
I've prowled the various forums, Facebook Groups, blogs, etc and have a pretty good idea of what the E-Trek is all about. It seems like most people have been happy with theirs but there have been problems. One concern is that not every rig has had the same problem and there are several different problems that have only impacted some E-Treks. Roadtrek seems to be constantly evolving the components in the E-Trek so it's hard to know exactly what you're getting.
I do like the idea of the tech onboard and going totally electric. We're not bothered by the small fridge or microwave on the floor. I don't LIKE that floorplan but it seems to be the main game in town. Everybody seems to go with that if you want 4 captains chairs, which is something we want.
So, my main question is, would you consider buying a USED E-Trek? The dealer has all the maintenance records and warranty work done and it's a pretty minor list of issues. This is just a complex motorhome and I'm hesitant to jump in. The pluses are that the Roadtrek warranty transfers and the blogs, Facebook, forums really make it easy to get help when something comes up. Plus this RV has already taken a big depreciation hit. The cons are that there is a lot that can break, I have little idea which issues may have cropped up or how the previous owner handled it, and everything is older and possibly abused (i.e. the AGM batteries).
Any thoughts would be most appreciated. Thanks.
05-13-2016, 07:07 AM
I'd want to speak to the prior owner. Especially if it wasn;t sold off for reasons of health, etc.
That said, if I were to sell you my rig, it has had zero issues.
2015 RT CS with E-Trek
05-13-2016, 12:03 PM
I'd consider a used Etrek.
#1 - I'd look for one that hasn't been idled all the time. Some folks may not have understood the limited idle time then highway drive recommendations. I wouldn't want is an "old" engine with 1,000's of hours of idling on a nearly new coach. I think the computer records the amount of idling time so it would be worth it to me to get a printout of that.
#2 - I'd be prepared to solve any problems encountered.
I think (correct me if wrong) that air conditioner run time ended up being around 5 hours with fairly new batteries etc.
Just a note: Lifepo4 (lithium) battery chemistry would seem to be the way powering these mostly electric coaches is going. AGM's (lead acid) need to be fully charged at least periodically. Lifepo4 batteries reported suffer no ill effects from being partially charged and then used.
Several owners have reported being happy with their E-trek's.
05-13-2016, 12:58 PM
Good point. This is via a dealer so the only thing I was able to get about the previous owners is that they put 25K miles on it in two years, used it a lot (with apparently minimal problems) and decided to trade it in (at the same dealer) for a new CS w/ E-Trek because the wife wanted a different exterior color and the larger fridge.
25K is pretty high mileage for 2 years, but I think it demonstrates that the RV likely didn't spend half its life in the shop. On the other hand, all the systems have been used a bunch which is opportunity for wear (and potential abuse).
Any ideas on the lifespan of Sprinter tires?
05-13-2016, 01:47 PM
If the OEM tires are the Continental Vanco Four Season many owners find those to be a poor choice compared to Michelin and switch even before they need replacing. I switched because the originals were 6 years old and we were heading out on a 14,000 trip to Alaska, I could have gone longer since they only had 25,000 miles on them and they were in good shape but the Alaska trip would have been pushing it. I do notice improved ride with the Michelins especially less harshness on expansion joints. We have a 2500 chassis 08 RS with single rear wheels so not easy to compare to the 3500 chassis.
Personally, I'd be scared to death to touch one. I am not into trying to fix someone else's errors, and be a pioneer, not only with newer technology, but worse, fixing another "pioneers" attempts at it. These units have been riddled with troubles, just read facebook for a day or two.
But even MORE IMMENSELY important than that, you said "I don't LIKE that floorplan", in bold no less.... Why would you spend that sort of money if you are not completely happy with the floorplan? The floorplan you want can be had, even if you have to build it or have it built. It's no bargain if you "don't like it", or have to rebuild it, or fix it..
In my opinion, the floorplan and the Chassis you like is the FIRST place to start; in the confined quarters of a B, it better be laid out the way you like. Power use can be dealt with in many ways, if you just don't like the floorplan, what good is it?
05-13-2016, 01:59 PM
No opinion on the merits of this particular vehicle. But, my take is that when it comes to RVs, you are less likely to be "fixing someone else's errors" than you are to be inheriting someone else's fixes of the manufacturer's errors. Sadly, almost all RVs come with screw-ups that the first owner ends up getting fixed. Not a bash on RT in particular.
05-13-2016, 02:02 PM
Used E-Trek?
I have a 2013 E-Trek with just under 50k miles. Still has the original Continental tires that will be replaced in the Fall. I recently had a battery equalizer installed on warranty and recommend that you check on whether that upgrade was performed on the unit you are considering. Also, make sure the Webasto DualTop is working properly. That's a component that would likely have to be removed and shipped to a Webasto repair facility rather than fixed locally. So a PIA if it does need repairs. Overall, like obgraham, my E-Trek experience has been very positive. I really like being mostly-electric and the openness of the cabin.
05-13-2016, 02:07 PM
OEM Continental tires are good for about 40,000 miles max on an RV. I have replaced two Sprinters after 36,000 and 37,000 miles with Michelins. My current RV has 38,000 miles after 15 months.
05-13-2016, 07:56 PM
I don't want to hijack my own thread and turn this into yet another floorplan debate, but I figured I should respond to this...
You make a fair point, but name one true B van with four captains chairs and a passenger side kitchen or a microwave & fridge not on the floor. As Davydd has pointed out, Roadtrek pioneered this floorplan and pretty much everyone else has copied it (Winnie, Airstream, Coachmen, etc). Since I do absolutely want the four Captains chairs, there are very few alternatives short of going the custom route. Custom will either cost more money or time and I'd rather spend my time using an RV than building it. As I said, I can absolutely live with the floorplan. Would I prefer a bigger fridge, passenger side galley, and face height microwave? Yes; but I'm simply not going to find it in stock. Life is all about trade offs and that is extra true in B floorplans. If I do end up buying a B, no matter the manufacturer, there is a 90% chance I'll end up with this floorplan. It's what is available and meets my other criteria quite well. But your point is well taken.
Now back to the E-trek:
Can anyone tell me a quick check to see if a battery balancer has been installed? From the boards it seems like some E-Treks needed it and some simply worked just fine without it. Other than maintenance records (which I hope to get), is there a quick visual check?
Also, is there a recommended test cycle to try out the Webasto? Obviously if it starts blinking error codes, something is wrong. Anything else special I should do?
Thanks for all the comments. Great stuff!
05-13-2016, 08:29 PM
Used E-Trek?
My battery balancer is in the storage bin over the driver-side rear wheel well in front of the sofa, so relatively easy access. I don't know if this is standard. Google Cooper battery balancer for a photo. My experience is that one's usage profile determines whether the balancer will make a substantial difference. Touring every day or two, which is what we usually do, not much difference.
Regarding the Webasto, definitely watch for error codes when powered up, and let it run for a half hour or so. Test hot water, which takes a while, heat, and the dump valve.
Also, turn the inverter on and make sure that the fan noise doesn't drive you batty. We rarely use the inverter, so it is not a big deal. I use a small silent inverter for the entertainment system.
05-14-2016, 03:33 PM
Good comments. Driving 2 hours to look at the E-trek today. Any last minute advice?
05-14-2016, 04:03 PM
Used E-Trek?
Check the solar controller for error codes. If outdoors you should be able see the amps being generated by the PV panel and battery voltage on the 24v system.
Ask salesperson to show you where the Webasto bypass valves are located for winterizing. (In the middle of undercarriage near rear axle - PIA to access.) Chuckle and wonder who made that decision. (I ignore the bypass valves and use compressed air to blow out the water lines and Webasto.)
Finally, having the E-Trek 6-year warranty transfer would be a big plus for me. A 2014.5 might include the AGM batteries, but you should confirm that. My experience with RT on warranty repairs has been great.
09-30-2018, 12:17 AM
Reviving the use E-Trek thread...
I thought I'd revive the thread.
We're also considering a used 2014 Roadtrek RS E-Trek and would like to get feedback on how they have aged. Thanks!
09-30-2018, 12:58 AM
I don't know how the Etrek coaches have aged but the initial Etrek production sure as hell aged their owners.
09-30-2018, 04:36 AM
What kind of aging are we talking about. Fine wine aged well over time.
09-30-2018, 05:12 AM
My 2013 E-Trek is aging just fine, as am I. The original AGM batteries are still functioning well after over 5 years and 80,000 miles of traveling. I don’t have anything to add to my previous comments in this thread. Just make sure any 8-AGM unit you consider has a battery equalizer.
09-30-2018, 09:04 AM
Originally Posted by Moose1790
Hi all,
Most people purchased the used RVs, it still works well and brings a lot of fun for the people. But I felt puzzled why you said that it's a pretty minor list of issues. What're they? And it's a complex motorhome and hesitate to jump in?
If you have such uncomfortable feelings, I don't think this RV is suitable for you. Maybe you can try another.
09-30-2018, 11:06 AM
That's really good to hear Arlo.
