I have a Chevy PleasureWay with two "Eyebrow windows" (That's what PW calls them) I tried the Captain stuff, but had to keep applying it, so I followed PW's instructions, and as others have mentioned, removed the gasket (No need to remove the window, at least on the PWs) cleaned everything up, applied a windshield glass urethane, and put the gaskets back in. Mine were in very good shape. (15 years old) The gasket is to hold the glass in, not for leaks, so I would be more concerned with a good bead of window urethane, than finding new gaskets.
