Old 07-25-2020, 03:38 AM   #21
Woops, I meant to say Delco as in Delco-Remy..... The only company I know using the Delco is Advanced RV.
Do you know what the model number is for the one they use?
Batt 57 is offline   Reply With Quote
Old 07-25-2020, 03:48 AM   #22
Not off hand. You can call ARV. They would tell you.
Old 07-25-2020, 03:54 AM   #23
Copy that. Thank you
Old 07-25-2020, 12:10 PM   #24
A bit of history for anyone interested ............
The first Roadtrek Etrek video from 8 years ago or so actually showed a small AC generator unit. It was a Fabco Power Mite. Maybe that's how the phrase Under Hood Generator came to be used. The Power Mite, generating AC, would actually be under the hood.
I am not aware of any RT that used an actual under hood AC generator though.
The UHG common to RT's consists of a DC alternator and regulator under the hood and a large inverter located somewhere in the coach.
Here's an old topic that includes several example of under hood AC generators: https://www.classbforum.com/forums/f...-etc-2544.html
