Old 07-12-2022, 02:28 AM   #1
folivier's Avatar
Default Roadtrek alignment specs?
Does anyone have the alignment specs for a 2011 Roadtrek Chevy 210 Popular?
Or know where I can find them. Mine is pulling a bit to the right and I won a free alignment (if they can do a Roadtrek).
Thanks.
2011 Roadtrek C210P
RZR 570, Ranger 1000
folivier is offline   Reply With Quote
Old 07-12-2022, 02:56 AM   #2
IMO, the published specs are way to wide and allow poor handling.
The best that we have found with out Chevy are as follows and pretty common for rear drive vehicles in general for good, stable, handling.
Caster--as much positive as you can get up to 6 degrees, with .3- to .5* more on the right compared to the left.
Camber-- 1/8* to 1*4 degree positive as the suspension is set up to be positive progressive on compression
Toe---Always in, never out, set at 1/16 inch to 1/8 inch in. Computer aligners will need to convert to the degrees their machines use.
Good luck finding anyone who will align to the above as nearly all shops now will say you are good when the machine is "in the green" which is the way too wide factory specs.
I gave up and do my own alignments at home.
Old 07-17-2022, 05:01 PM   #3
Looks like good information, but I don't understand what the asterisks and minus sign mean in caster and camber. Would appreciate your explanation.
2007 Chevy Roadtrek 210 Popular.
Roadtreker357 is offline   Reply With Quote
Old 07-17-2022, 05:08 PM   #4
The asterisks are degrees of angle.
The "minus" signs are just spacers to separate the items from the settings.
Old 07-17-2022, 09:14 PM   #5
Thumbs up
Thank you!
