Old 08-02-2020, 06:30 PM   #1
Default Roadtrek A/C Install
This is the sequel to the A/C Removal post I put up earlier. It turns out that installing a new A/C is more difficult than removing the old one. Unless you get a direct fit replacement A/C unit you'll need to get imaginative and have some metalwork skills.
The replacement A/C I got was a Frigidaire FFRA0611U1. It was very similar in size to the standard Fedders unit, the biggest difference was the depth of the new A/C - about 4" shorter than the old one.
I chose a Frigidaire A/C as they have good reviews on the consumer websites and claim to have a low-power start feature (so should work with my generator). The one I bought was 6000 BTU which is smaller than the standard unit but should be adequate, and has manual rotary controls which should be more reliable than the WiFi-connected electronic units out there.
Anyway, here's my experience of installing this A/C unit in my 1991 Roadtrek
YOU WILL NEED:
1. Selection of square (Robertsons) screwdrivers or bits – smaller sizes
2. Medium sized Philips screwdriver
3. Medium sized flat bladed screwdriver
4. Low profile ratcheting screwdriver
5. Power drill
6. Good quality hacksaw or other means of cutting metal (eg. Power grinder)
7. Some basic metalworking skills!
STEPS INVOLVED
1. Fit the old drain hose into the base of the new A/C. Before drilling through the A/C case check that there are no cooling pipes behind the place where you are going to drill! If you are reluctant to do this to your new A/C you could always drill a small (1/8”) hole near the base of the case, or remove one of the screws near the bottom of the unit. The drain hose doesn’t seem to be essential as it just directs the condensate further down the cavity to ensure it drains outside the van.
2. Your new A/C will likely be a different size to the old one. Mine was 4” shorter than the OEM one. This means the two baffles in the cavity need to be extended to reach the rear of the new unit. These baffles channel the warm exhaust air out of the van and keep it away from the cooling air coming in to the A/C. You could use ¼” plywood or some sheet metal, cut to size. I used some steel sheet I had in my shed, drilled some small pilot holes in the existing baffles and fastened the extensions to them with self-tappers.
3. Cut a piece of wood to the exact width of the rear of the new A/C. I bent the existing baffles (easily) to angle the extensions so they just rested on the piece of wood. The A/C should just slide between the new extensions.
4. Cut a piece of ¼” plywood to the width of the front of the new A/C, about 1” deep, and fasten it to the ½” plywood base that the bottom of the A/C rests on. This angles the A/C slightly backwards to improve drainage.
5. Put some silicone caulking along the bottom of the two baffle extensions. While this is still soft, slide the new A/C into the cavity ensuring the rear slides between the extensions. You may have to slide it at an angle and wiggle it a little to make sure it fits inside the extensions snuggly. Position the front of the A/C where you want it to be, resting it on the raised plywood constructed at step 4.
6. This step is the most tricky. You will need to secure the new A/C to the structure of the van somehow to prevent it moving around. The old A/C used two large screws anchoring the sides of the A/C to the wooden sides of the cavity opening. If you do this, drill small pilot holes where you want the screws to go into the A/C case, before installing it at step 5, Check there is nothing (wires, pipes, etc) behind the case where you are drilling the pilot holes!
I used some aluminum strip to make two brackets (one each side) which I screwed to the plywood base, and into the A/C casing by using existing screws from the A/C unit itself. This avoided the need to drill new screw holes in the A/C unit. Usually there will be lots of screws holding the two casing halves together – just pick a suitable one and remove it. Make the brackets and screw them to the A/C using these existing holes and screws.
Securing the new A/C will require some imagination and metalworking skills as each A/C will be different and there is no standard approach here.
8. The old A/C had the vanes on the side vents cut away. I soon realized why – the top vent will be blocked by the vinyl ceiling resting on it. I didn’t want to destroy the side vents on my new A/C so I wedged two pieces of plastic (or wood) to the top of the unit and securied them with a dab of silicone caulk. This held the vinyl ceiling fabric off the top of the A/C by about 3/8” so air can flow into the top as well as the sides.
9. Most likely there will be a gap around the new A/C as it will not be the same size as the old one. To finish the job you will need to make a trim to fill this gap. My new A/C came with a plastic expanding window frame kit which I adapted to fit around the new A/C. Another alternative would be to use some ¼” plywood, varnished for appearance.
10. The rest of the job is straightforward. Align the overhead cupboard frames (after routing the power cord properly) and reinstall the two screws holding each in place. The inner wood panels inside the overhead cupboards (if removed) can now be refitted. Finally the cupboard doors can be remounted.
11. Here’s a photo of the finished unit
Dodge 190 Versatile is offline   Reply With Quote
Old 08-02-2020, 10:47 PM   #2
Nicely documented. I just hope 6K btu's is enough for you. My Airstream Avenue (think RT 190P with galley and bath reversed) came with a 13.5K roof unit. When I replaced it, I ordered the same size but was shipped a 15K in error. After seeking advice on this forum, I decided to keep it as it was only 12% larger and being newer, used less amps than the older unit.
I know that's a ton of btu's and seems ridiculously large, but forum members reminded me that the dash air is probably in excess of 20K and it will barely cool the rear on a hot day.
The 15K cools well, of course, but in my experience is not too much ac. On cool days & nights, we've never had a problem with it not running long enough to dehumidify and on the hottest days, the front cab still stays 10 degrees warmer than the back. And that is with heavy reflective windshield and side window coverings.
I'm curious how it cools in a Rhode Island Summer in full sun.
Old 08-03-2020, 01:49 AM   #3
I was restricted in size to the amount of power my generator could put out. I mounted the generator on the rear spare wheel frame to keep the noise down inside, so I was limited to one of the portable inverter generators. The biggest one I could find that would physically fit was a 2000W (peak) which kept tripping with the stock A/C, but the A/C would work on shore power fine. If the stock A/C would work on my generator I wouldn't have replaced it (I don't expect to ever hook up to shore power at a campsite). The 6000 BTU A/C was similar in size to the stock A/C and had the Frigidaire soft-start feature. We had a heatweave here this week (100+F) and it DID work effectively at bringing the temperature down, but (as you say) I also doubt it would be very effective in Florida (or Texas!) in July. I'lljust stay north in the summer months!
Old 08-03-2020, 04:29 AM   #4
Sounds like it will work for you. I must clarify that after all I've said previously about my air conditioner, we've actually rarely used it. Maybe 10-15% of travel nights since we try to stay in cool weather. We've actually used the heat more than the ac.
When it's this hot out, we'd rather be in ac at home rather than in our cramped class b.
