Originally Posted by honeyboy
I have two Friends who attempted to do this they were successful, adding the takeoffs, but neither of them had enough pressure to run a barbecue. Make sure if you bother to go through the time and expense to install a takeoff that it will run your barbecue.
It all depends on the grill and where you put the takeoff.
The other stuff in the van will be at something like 11" of pressure and run of the regulator. If you have a grille with a low pressure regulator speced to low pressure it will work fine.
If the grille is the more typical for home, 20# tank, setups it will be high pressure which is way higher of pressure at near 100 psi. If you have the high pressure grille it will work fine.
Many grilles with have both regulators available, but many don't also.
Most RVs now use low pressure as it is safer if you get a leak and is less likely to trip an overflow shutoff is on a long hose when you turn it on.
Older Roadtreks are worse yet as they run at 10-15psi on a separate regulator so some will run on it and some won't won't.
