Old 09-22-2022, 06:59 PM   #1
Default Roadtrek 06C210P roof leak?
Have a 06C210P and have to replace the "well nuts"
on the roof cover over the A/C unit because of a leak. Does anyone know what size they are?
topwop is offline   Reply With Quote
Old 09-29-2022, 08:04 PM   #2
On our 200 I simply measured the diameter of the holes and got that size. Sorry, I don't remember what it was.
Old 09-29-2022, 10:25 PM   #3
well nuts are available in many sizes at any hardware store.
I'd pull off the old, then match them at home depot ( etc) or if you can wait order from amazon.
you want the correct diameter and also the length
Old 09-30-2022, 02:32 AM   #4
I replaced the A/C cover fasteners on an 07C210P, and found that there were both well-nuts and riv-nuts used. and not all the same diameter. A couple of the OEM fasteners would not screw in far enough (screw bottomed out on something) so the washers were not held tight and could rattle. After cutting the screws shorter, these screws fastened correctly.
I'm trying to say that you should remove the existing fasteners to access what you have and then get the readily available fasteners to reattach.
2007 Chevy Roadtrek 210 Popular.
Roadtreker357 is offline   Reply With Quote
