Thanks.
I have already read a lot on this forum about the low ground clearance problems inherent in the Chevy based Roadtreks, some of the fixes, etc., and I continue to research the problem. Still, from your picture, it seems, even with a 2" lift, that the excess hose that dangles down would be subject to snagging on something.
Originally Posted by GroupB
I, like others, have replaced the front coil springs to provide the proper nominal ride height for this always-loaded-to-the-max vehicle. I have also added rear air bags. Provided a ground clearance increase of 2 inches, which satisfied my need to reduce the vulnerability of the macerator.
Many hours worth of reading on this topic in this forum.
