Old 05-17-2022, 09:17 PM   #1
Default Pleasure Way Shower Material
I'm considering a PW perhaps the OnTour. I am evaluating the bathroom. It appears to be made from laminate panels with caulk between them to prevent leaks.
1) How do you. clean the walls?
2) Does it leak?
3) Why is it not fiberglass as in some of the other/older PW models?
triflex is offline   Reply With Quote
Old 05-29-2022, 06:05 PM   #2
The OnTours have a wet bath. The walls are designed to get wet if you use it as a shower.
You can simply wash the walls or wipe them down after showering to clean them.
bl_smith25 is offline   Reply With Quote
Old 06-03-2022, 02:40 AM   #3
Thx. I just bought one last week. Now I need to find a small antenna to replace the big one.
