Old 05-15-2020, 05:12 AM   #1
Default Jack location
Would anyone know of the jack location in a 2006 R-Vision Town and Country Touring sedan Class B+ on a Chevy Express 3500 cab/chassis? I can't seem to locate it anywhere and I am wondering if there is a secret location that I have overlooked or if the previous owner kept it.
Thanks
cwilsun is offline   Reply With Quote
Old 05-15-2020, 10:55 AM   #2
There's a good chance that it didn't come with a jack from chassis manufacturer. I don't recall having an included jack in the Rvision I had nor a larger Class C or Class A.
Old 05-15-2020, 05:06 PM   #3
Mine is in the back on the right side lower wall.
Old 05-15-2020, 09:05 PM   #4
Don't worry about it. It isn't strong enough to do the job anyhow. You will need to buy a 3-stage bottle jack short enough to get under the axle with a flat tire and enough lift to get the axle high enough to put an inflated wheel and tire on.
It seems 3 stage bottle jacks are no longer available. Try for the shortest 2 stage you can find and see if it has enough lift.
