Old 09-05-2019, 09:23 PM   #1
Default color 1999 Roadtrek 190 versatile
I need to repair a couple of cracks in the Roadtrek 190 Versatile storage lid. Does anybody know the color code for the paint used on the storage lid? If you know would you share that info?
B
Boyde is offline   Reply With Quote
Old 09-06-2019, 05:14 PM   #2
If you're lucky, there may be a paint code on a door sticker. Also, posting a picture may help others who have the same color and know the paint code.
Also, another thing to consider is new paint (even the exact original color) may not match the 20 yr. old paint on your van. I wonder if the automotive paint shops have a service like the hardware paint stores to match a color if you can take in a panel as a sample?
Good luck.
Old 09-06-2019, 07:34 PM   #3
The door sticker lists the main paint code for the chrysler white PW6. Does not seem to list the secondary color. Here is a couple of Pics to show what I am looking for.
Hope someone can help.
Old 09-06-2019, 08:00 PM   #4
Default Roadtrek colors
I think I found the color codes for the older Roadtreks, found it in a whole Goggle search. Hope this is helpful to some other folks.
Here are the color codes for the old-school roadtreks with white bodies and blue/tan/green trim:
ice blue pearl is PPG#16842
mocha frost metallic is PPG#4282
grey green metallic is PPG#400528
White Chrysler White PW6
Old 09-07-2019, 12:33 AM   #5
Now you're getting somewhere. You need to hit up your local PPG Automotive Paint Store for their opinion.
Good luck.
Old 09-12-2019, 05:20 PM   #6
The best thing to do is bring the part you need painted to your autobody shop or parts supply store. Most will have a scanner that will allow paint to be mixed to match the color of the part as it is now. Paint codes will give you the color of what it looked like 20 years ago.
Call around to find out which shop can do this for you.
ThunderAce is offline   Reply With Quote
Old 09-12-2019, 06:43 PM   #7
This is an off the shelf blue that was very close on my 99D190V. Dupli-color Light Blue Metallic BGM0539 (21 WA7470) Replaces T155
SQUASHMIRE is offline   Reply With Quote
Old 04-24-2020, 08:51 PM   #8
Default '97 Dodge 190 P
Hey,
I don't think we're looking for the same color but similar..... The paint description on the door jam for the storage area/rocker panels says Orchid. I can't find a match on the auto color library or with Dupli-color charts.
Has anyone been successful find this color. I need to cover some scratches.
jujuhound50 is offline   Reply With Quote
Old 04-29-2020, 06:33 PM   #9
Default 1999 roadtrek 170 blue color
My 1999 Roadtrek 170 has a sticker on the driver's side door that lists two Dupont paint codes. The "Chassis" is PW6 and the "Deluxe" is B8343. I assume the first is the white color of the body and the second is the blue color of the fiberglass. I attached a picture of the blue color of my RV. I came across a place online that sells paint with this code, though I do not know how good of a match it is. If anyone tries it let me know, because I have some touching up to do.
https://www.paintscratch.com/touch_u...oat-B8343.html
Old 05-01-2020, 02:01 PM   #10
The burgundy on the Dodges is likely PE9, Cordovan, based on my conversations with Roadtrek but they said I should just get a colour match due to fading.
Roadtrek probably used an available factory colour when they did the other colours.
Stevemo is offline   Reply With Quote
Old 05-01-2020, 08:11 PM   #11
Originally Posted by jujuhound50 View Post
Hey,
thanks..HarryAttachment 9027
Thanks to rowiebowie I believe I was able to get a local paint store to match the blue on my 97 Dodge 190 Roadtrek. --ice blue pearl is PPG#16842
I'm hoping that I can do a decent job getting the sanding - priming & paint on!
Thanks 'rowiebowie' !
