Old 02-06-2024, 12:50 AM   #1
Default Can anyone with a Sprinter Van confirm if it sound like a hurricane at higher speeds?
Hello.
I have a new Mercedes sprinter van and the passenger side door sounds like a hurricane on the highway.
I'm not sure if this is normal or if there is a problem with the window seal.
Can anyone with a sprinter van confirm or deny if they also have this issue?
Thanks.
MysteryMachine is offline   Reply With Quote
Old 02-06-2024, 01:44 PM   #2
My son’s 2017 MB has zero noise from any of the doors. Very quiet on the highway.
Old 02-06-2024, 06:39 PM   #3
My 2013 Sprinter is very quiet since new. You can use automotive stethoscope (without the vibration amplifying rod with its membrane) to trace leaking weather seals.
https://www.amazon.com/Lisle-52750-S...38&sr=8-5&th=1
Old 02-06-2024, 08:42 PM   #4
Boxster1971's Avatar
My side door is quiet. What brand is your Class-B Sprinter? Door may not be adjusted right to close tightly or converter has added something to inside of door to prevent it from closing all the way. Is it a manual or power sliding door?
Edit: Just checked your profile and see you have a GrechRV. Contact them about getting your door adjusted.
Old 02-07-2024, 09:01 PM   #5
OK, thanks. I will.
Old 02-11-2024, 11:38 PM   #6
If there is a door or window problem, you need to contact the local MB dealer because this will be treated under the Sprinter vehicle warranty.
Grech warrants stuff that they manufactured and installed in the van.
Individual suppliers warrant equipment installed in the van such as the refrigerator or AC.
George
GeorgeKG is offline   Reply With Quote
Old 04-04-2024, 06:41 PM   #7
Originally Posted by MysteryMachine View Post
OK, thanks. I will.
Hey, did you end up successfully getting the noise fixed?
-Rob
Rob in Richmond is offline   Reply With Quote
mercedes, passenger door, seal, sprinter, wind
