No seal on that cover. It is held on by screws that go into inserts in a flange under the cover, that is formed like a channel to carry the water, mostly, to the rear. It is quite common for the inserts to come loose and leak or the sealer on them to leak after a while.
If you try to remove the screws to get the cover off to look at what is going on, you may find some corroded into the inserts so the inserts spin or pull out and would need to be repaired. Getting the inserts sealed well and a clear path for water draining will help any leak issues, but some still have them.
