4x4 Conversion + 3" lift on 2012 Chevy Roadtrek
Bravelion
Joined
Aug 4, 2019
Messages
5
I thought I'd share some pics from my recent 4x4 conversion with 3" lift on my 2012 Chevy Roadtrek Popular 190.
This was done by Advanced 4x4 in Salt Lake City using mostly chevy Silverado 4x4 parts. They do them on brand new Chevy Express vans for fleets and this is the identical conversion as done on new.
I also added Bilstein shocks and rear Sumo springs. It drives incredibly nice, better than stock.
Next up I'd like to upsize from 245 to 265 tires, and in researching it looks like I'll need Chevy Silverado 17" steel wheels. The bigger tires might give it another 0.75" of clearance.
Conversion includes:
- GM 9.25” IFS Front Differential 1
- Heavy Duty 2 Speed HI-LO Transfer Case
- Shift on the Fly 4×4 Front Engagement System
- Spicer Front and Rear Drivelines
- Heavy Duty GM Torsion Bar Front Suspension
- In-dash 4X4 Indicator Light
- Maintains Factory GM Stabilitrak and ABS Systems
Options
- 3 Inch Lift
- Bilsein shocks
- Sumo springs
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Looks good. Now you need some AT tires and some under body armor. While the lift helps, still lots of vulnerable stuff underneath.
And maybe some of those cool video cameras that Show whether you're about to smash up your underside. I sure could use some about as much as any B out there.
Look good. And all your parts references will help others considering the same mods.
All the class b cladding and underneath additions really take a toll on road clearance. Not to mention the spring sag from the extra weight.
I'm surprised the manufacturers never offered a "lift" option. Especially considering it mainly restores the suspension to closer to OEM.
Hi Bravelion, What are your wheel well measurements on a level surface from the ground up thru the center of the wheel to the wheel well lip on all 4 corners? I have a 2006 Versatile 190 4X4 installed new by Quigley. Mine are 36 ½” front and 37” and 37 ¼” rear with full water tanks and fuel. Just curious with your being a new install.
Hi Bravelion... can you give me a ballpark price for what Advanced 4x4 charged to do the conversion? I've already upgraded to Bilsteins, SumoSprings and front coil spacers which gave me a 2" lift all around and greatly improved handling, but 4WD is enticing.
That looks really good! You’ll probably recoup much of your costs at resale. As others have asked what was your cost? Also consider a little bit of skid plating especially near the oil pan, transmission pan, and possibly the tank drains. FYI Truckcamperadventure has a really good write up in tires.
Congratulations on a nice upfit. The job looks 100% OEM caliber.
The handling improvement itself must have made it work it. How much did it run total? Do they refurb the parts used before installing or are they new parts?
Note All Terrain tires tend to generate more road noise so may want to take that into consideration as you weigh the options.
Congratulations on the move to modify and the results there of. ENJOY. UT has so many great places to explore, its simply amazing and beautiful.
I too would be interested in the ground clearance from the fender lip above the tires to the ground on all 4 tires. I also have the Quigley conversion. THANKS
@Bravelion: Just realized that your location is in TX and the upfit was in UT WOW. How did you manage that?
Again Congratulations on a great upfit. The roads in TX seem to generate more road noise via tires than in most other states, wonder why they choose such a noisy road surface finish. In PA and OH there are roads which are tuned to create music as you drive down the road! Totally amazing. Guess the thundering long horn noise is near and dear to the Cowboy soul of TX!
  • and much more...
Try RV LIFE Pro Today
Back
Top
