Thread Tools Search this Thread Display Modes
Pleasure Way Plateau TS . . . . For sale
Sprinter lover Sprinter lover is offline
Registry
RV Name Pleasure Way Plateau TS . . . . For sale
Year 2006
Make Pleasure Way
Model Plateau TS
Length 22' (21' 11")
2006 Pleasure Way Plateau TS
2006 Pleasure Way Plateau TS 2006 Pleasure Way Plateau TS 2006 Pleasure Way Plateau TS
Basic Info 2006 Pleasure Way Plateau TS for sale:
Due to health reasons and, with much sadness, the time has come to sell our beloved Pleasure Way. We have owned and used our Pleasure Way for four years and for most of its life it has been pampered and cared for meticulously. We are mature, adult owners, non-smokers, non-pet owners and like the original owner, have taken particular care of our beloved TS. This RV is in perfect shape, in and out, --you will be hard pressed to find a better cared for motorhome. We have all the manuals for all systems and appliances, all service receipts (including the original owners), brochures and maintenance and service records for the entire history of this fine vehicle. This motorhome is fully self contained and very economical to operate. On our last trip out West, we averaged 21 mpg with a high of 22.5mpg at 70 mph. This rig is perfect for two people (a couple), is easy to drive, and will park in any regular parking space. This very hard to find unit comes with a 260Ah house battery (was purchased in October of 2020) which is excellent for dry camping, plenty of Amp-hours to power your needs. One thing I've noticed is there are not a lot of 2006's in the marketplace now or ever for that matter. As I look for them, I often find a lack of them available!
This unit is the one you want to acquire. I have had numerous fellow campers always inquire about this rig and want to peek inside, which I enjoy bragging on its accommodations. We would entertain serious inquiries only.
Offered at $54,900, contact Geoff at 727-514-8902. Calls please, no texts.
Location: Port Richey, Florida(35 miles NW of Tampa, FL)
HIGHTLIGHTS: length, 21' 11
Odometer: 135, 5xx(purchased from original owner in 2016 with 108,000)
VIN: WD0PD744055844307
ENGINE: Mercedes Benz /Dodge 2500 Sprinter chassis 2.7 L 5-cylinder turbocharged DIESEL engine--hugely reliable and trouble free engine and 5-speed transmission. As the original owner did, I have also changed oil every 5,000 miles. It represents what I call cheap insurance. Be advised, this is NOT the V-6 in my RV, they will be experiencing some very expensive repair problems with those engines soon. In deference to the Mercedes image, I rebadged the unit with the Mercedes star in the front and the "Mercedes Benz" on the rear door. There is a lovely Mercedes 3" button on the steering wheel center. Oh, and as a note, I never run the engine over 3,000 rpms even though the manual says 4,000.It is just my way of being conservative in its operation. (Also, I usually run at 65-70mph)
-Averages between 21-22.5mpg.
-Sleeps two
-Everything works as it should, you could use it
immediately for your next adventure
-NEVER USED for towing. It does have the tow unit
on the rear with electrical hookup and receiver.
-GVWR 8550lb
-Dry weight: 6878lb
- Recent service includes oil change (0-5w Mobil 1
229.5 spec full synthetic), new oil filter, new fuel
filter, new air and cabin filters. So you are set on
those for another 10-15,000 miles.
RECENT UPGRADES:
- New high efficiency LED bulbs in all interior
overhead ceiling lamps for all interior lighting.
Cuts down massively on energy useage.
-Aspire CD HD radio receiver--has all the bells
and whistles you could ever want. USB port,
Pandora, and iHeartRadio.
-New speakers mounted mounted over your ear
in cockpit. (Cab noise can be a tad noisy at
speed)
- Newer Hancock tires--put on 1.5 years ago,
plenty of tread remaining. By the way, I use
tire covers any length of time it is parked. We
travel every 3-4 months.
- New carbon monoxide & propane detectors
(you should change them out every five years.
Replaced mine last year.
- New back up camera. Set up to work constantly,
to see when you are pulling a toad.
- New turbo resonator, the OEM one is plastic!!
And the plastic ones keep breaking, bringing on
limp home mode, not fun. This is the newer
aluminum replacement!! This is important.
- We have the Winegard directional amplified HD
TV antenna(all we do is put the antenna up, turn
it toward a city nearby, then on the TV, do an auto
channel search, then sit back and enjoy)
Exterior
2006 Pleasure Way Plateau TS Exterior 2006 Pleasure Way Plateau TS Exterior 2006 Pleasure Way Plateau TS Exterior
EXTERIOR SPECIFICATIONS
- 13 ft Fiamma awning—excellent condition
- Exterior shower with hot and cold
- Convenient utility hookup center
- Frameless awning style windows
- External storage compartment on rear passenger
side
- Winegard HD directional TV antenna with
booster
- LED porch light
- Locking fresh water fill
- Locking sewer hose stowage
- Rear undercarriage full size spare tire
- Exterior cable hookup(with 50' hookup cable)
- Phone jack (we use cells exclusively)
- 120v receptacle
- Fiberglass running boards
- Exterior height 9' 6”(including roof air)
- Exterior length 21' 11”
- Exterior width 6'6” (without side mirrors)
- Aluminum mag wheels
Interior
2006 Pleasure Way Plateau TS Interior 2006 Pleasure Way Plateau TS Interior 2006 Pleasure Way Plateau TS Interior
COACH SPECS:
- 2.5kW ONAN propane generator with remote
start. (76.3 hours on it)
- Dometic 3-way 4 cu ft refrigerator--its amazing,
runs on 120v,12v, or propane. It won't use up
your diesel.
- Sharp Carousel microwave AND combination
oven. Excellent device!!
- Suburban 2-burner propane stove.
-16,000 BTU auto ignite furnace
-Shurflo on-demand pressurized water system.
-6 gal Suburban auto-ignite propane water heater.
- LP detector, CO detector, smoke detector.
- 3.5 lb new fire extinguisher.
-monitor pane shows levels of house battery,
propane tank, gray and black tanks levels.
- Gray water tank: 24 gal, 91 ltrs
- Black water tank: 12 gal, 45 ltrs
- LP tank ;12 gal, 45 ltrs
- Interior standing height: 72"
- Aisle width: 27"
- Memory foam Queen size bed, 74" x 68"(when I
got the rig, I had the couch, both ottomans and
two bolsters recovered in ultra leather to match
the seats in the cockpit.
- Driver and passenger seat are in ultra leather
- Passenger seat swivels to face rear of coach.
- BRAND NEW Fantastic Fan with the newer
remote. Just installed, very low profile above and
below.
Customizations
2006 Pleasure Way Plateau TS Customizations 2006 Pleasure Way Plateau TS Customizations 2006 Pleasure Way Plateau TS Customizations
KITCHEN or GALLEY
- 4 cu ft Dometic 3-way fridge/freezer(powered by
propane, 120v, or 12v)--works very well, it does
the job.
- Dometic built-in microwave/ convection oven
(just below 2-burner stove top)
- 6-gal Suburban auto-ignite water
heater(propane) (just below oven)
- Suburban 2- burner propane stove top
- Overhead vent (Fantastic Fan) with remote.
Always use this fan when you are cooking. It'll
keep the smoke alarm from going off.
2 slide out counter extensions. Equals more
space!!
- Sink with hot and cold running water.
- Spice and towel racks
- paper towel rack
- Tons of storage space for an RV this size!!
- Wardrobe closet, large deep drawers, large
overhead cabinets.
Renovations and Repairs
2006 Pleasure Way Plateau TS Renovations and Repairs 2006 Pleasure Way Plateau TS Renovations and Repairs 2006 Pleasure Way Plateau TS Renovations and Repairs
SLEEPING
- Power sofa converts into a Queen size memory
foam
bed (74” x 68”) or two twin beds.
- Comfortable memory foam
- Large overhead cabinet to store bedding and
pillows
DINING
- Removable dining table in front of TV
- Can get four at the table, just a little tight!
PRIVATE BATHROOM
- Thetford flush toilet
- Sink with hot & cold running water
- Vanity under sink with storage cabinet and 2
drawers
- Medicine cabinet with large mirror
- Shower with hot and cold running water & wrap
around shower curtain
- Roof vent
- Towel bar
ENTERTAINMENT
- 19” flat screen Samsung LCD TV with CD/ DVD/
- MP3 player and with swing out cabinet HD
Winegard directional antenna with amplifier to
bring in those hard to get stations.
- Premium sound system with 300 watt amplifier
and 4 stereo speakers
- 800 watt inverter-converts 12 volts DC to 120
volts AC to power entertainment system from
house battery.
- Exterior cable hookup(with 50' of cable)
- HD recorder/player
SAFETY
- Newer Hankook tires with lots of tread
left(always check for 80 lbs rear and 55 lbs
front.--your best for wear, and rotate for better
life and remember to refill for air!!
- 4-wheel disc brakes with ABS
- Back up camera with 7” color LCD Monitor in
- driver's dash(always on with key on)
- Dual airbags (80 psi) on rear wheels.
- Power locks, windows, and mirrors
- Large power side rear mirrors
- 3.5 lb new Fire extinguisher
- Seat belt seating for 5
- Driver and passenger side air bags
Tow Vehicle
2006 Pleasure Way Plateau TS Tow Vehicle 2006 Pleasure Way Plateau TS Tow Vehicle 2006 Pleasure Way Plateau TS Tow Vehicle
CHASSIS SPECIFICATIONS
- 8550 lb GVWR
- 2.7L 5-cylinder Mercedes Benz Turbocharged
diesel engine
- No expensive DEF emission system repairs
to worry about!!!
- Does NOT require low-sulfur diesel fuel—no
problem traveling in Mexico
- 154 HP @ 3800 rpm
- 243 ft/lb @ 1600-2400 rpm
- 3.72 rear axle ratio
- 5-speed automatic transmission with touch shift
-- 158” wheelbase
- Power door locks
- Chassis air conditioning(cold and very
comfortable)
- Cruise control
- Power windows
- Power side mirrors
- 4-Wheel disc brakes with ABS
- Driver and passenger airbags
- Aspire CD HD-radio receiver with bluetooth for
hands free calling and audio streaming, USB
port, Pandora, iHeartRadio.
Favorite Camping Destinations
2006 Pleasure Way Plateau TS Favorite Camping Destinations 2006 Pleasure Way Plateau TS Favorite Camping Destinations 2006 Pleasure Way Plateau TS Favorite Camping Destinations
Favorite camping spots?? Anywhere close to the water or after driving for 6 hours, anywhere that I may rest my head for the night. I enjoy the travel, seeing this grand land, the sights, the variety, everything about travel is continually exciting for me. And that's why I love RVing, I only wish my body would allow to do more, but alas, it is what it is.
