Thread Tools Search this Thread Display Modes
Killer B
ClassBLiving ClassBLiving is offline
Registry
RV Name Killer B
Year 1984
Make InterVec Falcon
Model M190SL
Length 19 feet
1984 InterVec Falcon M190SL
Basic Info Dodge Ram B350 Royal chassis.
Purchased it for $300 needing interior rehab and some bodywork.
Interior
1984 InterVec Falcon M190SL Interior 1984 InterVec Falcon M190SL Interior 1984 InterVec Falcon M190SL Interior
Gutted and redone.
Pergo floor, futon replaced jackknife sofa, new kitchen with butcher block countertop, one burner cooktop, big buddy heater tied into brand new propane system, 6 speed reversible vent fan and two under cabinet fans, new dorm fridge and 23 qt 12 volt fridge, all new plumbing, 12 gallon fresh water tank, 5 gallon portable toilet, tankless hot water.
Customizations
645 watts solar, 60 amp MPPT charge controller, 30 amp DC to DC charger with isolation, 300ah LifePo4 battery, 1,200 watt pure sine inverter, 45 amp three stage converter/charger, quick charge USB ports, Mini PC with 24 inch screen. No AC in dash or living area. 30lb propane tank with exterior venting for pressure relieve valve and exterior venting underneath, LP leak detector, CO/smoke detector and fire extinguisher.
Renovations and Repairs
1984 InterVec Falcon M190SL Renovations and Repairs 1984 InterVec Falcon M190SL Renovations and Repairs
360LA (5.9), Edelbrock performer intake manifold, Holley 4 barrel carb, Hooker headers with dual exhaust, MSD ignition system, rigid radiator fan. inline electric fuel pump (no mechanical pump). Transmission is a 4 speed 46RH converted from 727 by previous owner, Dana 80 rear end with original 12 X 2.5 brakes from old rear end done by previous owner. 4 new 16.5 inch tires, all new brakes.
New custom dash cluster with GPS speedometer, Glowshift analog clock, alternator gauge, mechanical temp gauge and mechanical oil pressure gauge, no fuel gauge, go by trip odometer. Complete new custom under hood wiring harness (original burned up)
Tow Vehicle
None
Favorite Camping Destinations
None yet.
Old 06-29-2023, 06:41 PM   #2
Nice, my Dad’s business had
72 1 Ton long body Dodge van. It was a beast!
Have fun!
TooMuchHair is offline   Reply With Quote
