Old 03-08-2021, 06:51 PM   #1
Default Where to get replacement water tank 1999 PleasureWay
We have a 1999 PleasureWay Excel and need to replace the fresh water tank. Where can we find the right replacement?
Dianne D is offline   Reply With Quote
Old 03-08-2021, 09:11 PM   #2
You can email PW and ask them if they have any left over or where one can find it. Also go onto FB PW owners and post this question. I do not know the configuration but many water tanks are custom sized for manufacturer.
Old 03-08-2021, 10:13 PM   #3
I've looked up RV tanks before, plastic-mart.com, I haven't purchased from them so I can't give you a positive or negative recommendation. Their website is easy to search and it gives prices. On the left side is RV water/holding tanks.
Some RVs have custom shapes, my PW water tank seems standard.
Old 03-15-2021, 03:16 PM   #4
Hatteras Jim's Avatar
I had a custom tank made at "plastics" for my homebrew Sprinter. It was perfect. Holes where I wanted them and properly sized as well. Great communications and they reaffirmed all of my selections to make sure it was done right the first time. Be sure to get a clean-out installed, in case you have to access the tank's interior in the future. If you can't find one already made, they would be a great second choice.
Old 03-15-2021, 09:17 PM   #5
Thanks so much! When you say "plastics" is that plastic-mart.com?
Old 03-16-2021, 02:10 PM   #6
Yes. That's the one. I needed a small tank (7.5 gallons) to fit behind the interior rear wheel bump. I picked one that would fit and then contacted them by phone. I drew up the initial diagram on where I wanted the vent hole, fill tube and main siphon line. We exchanged a few faxes and then finalized. The salesman I worked with was excellent and knowledgeable. It is a heavy duty tank and the fittings are expertly welded into the tank. I sanitized my tank every year and pull it from the van during the winter. The clean out makes it easy. Good luck.
replacement watertank
