Old 06-26-2013, 10:09 PM   #1
Default Rotopax opinions?
I do know they are relatively expensive compared to a 5 gallon gas can from Lowe's, but they can be mounted vertically and horizontally, and with a locking T-handle, will do a good job at resisting theft (it is likely a removal attempt without the key would damage the fuel containers to the point where they can't be used.)
Anyone like/dislike these containers? I wonder if they are worth the expense, because I plan to carry them on a hitch mounted cargo rack. That way, I can carry around 10-20 gallons of extra fuel to feed the generator if the weather turns too hot/cold, and the locking handle will go a ways to keep honest people honest. I also plan to see about using security screws/bolts to ensure that the pack mounts can't easily be wrenched off.
Old 06-26-2013, 10:57 PM   #2
Default Re: Rotopax opinions?
See lots of people using them on Jeeps etc. motorcycles too - "Overlanders" & DualSport; Not the ones that look like a Barcalounger...
I use similar called CamCans on my Jeep. Different mounting & security system, little cheeper too - but very tuff material like RotoPax
AZ ADVenturist is offline   Reply With Quote
