Old 12-06-2018, 02:59 AM   #1
Default reading light
I need a very bright stick on light above my chair. It has to stick to the soft, vinyl ceiling. The one I got,with 6 LED lights is not bright enough.
I've looked at lights and most of the stick on kind don't seem bright enough.
Any suggestions?
soohma is offline   Reply With Quote
Old 12-16-2018, 05:31 PM   #2
Consider a headband=style light (I like Petzl). Gives you bright light wherever you look and works great for reading, sewing, crafting or reading in bed. If use often, consider a rechargeable version.
Old 12-16-2018, 07:46 PM   #3
That's a thought. Thanks for the suggestion.
Old 12-16-2018, 10:53 PM   #4
I bought this light on eBay - Daffodil USB Reading Light Lamp Bright LED Flexible Gooseneck and Desk Clamp it was $12.00
It works great.
webminer2 is offline   Reply With Quote
Old 12-16-2018, 11:43 PM   #5
Thanks. I might be able to clamp it to railing around the top. What are the lumens, do you know?
Old 12-17-2018, 12:56 AM   #6
I don’t know but it is much brighter than anything else I have found. It has three settings for brightness. I use it all the time on the second setting since it is so bright. Check it out on eBay. Don’t pay any more than $12.00.
high lumens, reading light, stick on
