Old 09-16-2010, 02:44 AM   #1
Lee
Default Model 250 Quick Disconnect Plug hose assembly
I found the below information from another site. The company stated does not allow to purchase on line. Can anyone help me find this connector? Canada would be good!
Recently I posted part numbers for the connector(s) for an RT that
allows the connection of a grill or stove to an RT propane tank to
avoid hauling the portable tanks.
www.mbsturgis.com sells fittings and connectors.
The hose with connector 9' long including connections is available for $24.99 and
should work. The part no. is 100476-120. For 5' the part no. is 100476-
60 for $19.99. The Sturgis Co. is pleasant to deal with but they will
not accept returns.
Lee is offline   Reply With Quote
Old 09-16-2010, 11:28 AM   #2
Default Re: Model 250 Quick Disconnect Plug hose assembly
Lee - take a look at this link:
http://www.classbforum.com/phpBB2/vi...php?f=9&t=1044
for info re: suggested hose lengths etc.
The hose can be ordered through any Roadtrek dealer. It costs a bit more though.
Old 09-16-2010, 03:44 PM   #3
These guys will make you any hose you want, with the connections of your choice. They made us a 15' propane hose with the male QD for the Roadtrek end, and a female, free spinning nut, adapter that is the same as a 1# bottle on the other end. I also had them make a "Y" hose that is the male 1# bottle fitting (same as regulator) and two of the female ends, so we can put it at the end of the 15' and run the grill and stove at the same time off the Roadtrek. They were very reasonably priced, and easy to deal with.
http://www.propaneproducts.com/
