Old 01-29-2019, 08:03 PM   #1
Default Looking for replacement fridge vents for 1988 Ford
Looking for some replacement vents for my 1988 Ford Class B camper. Any links to a website would be fantastic thanks in advance.
cramerrr is offline   Reply With Quote
Old 01-30-2019, 12:01 AM   #2
There are a lot of different sizes. Measurements of the hole would be good. Top or side?
Perhaps do a google search for rv fridge vents and then go to images and see what you find.
Old 01-30-2019, 08:31 PM   #3
They are the side vents and they measure
20 inch x 12inch
Old 01-30-2019, 10:24 PM   #4
One possibility if your can't find an exact fit is to have a plexi-glass cutout made to fit the opening. Then, if you could find a close (but slightly smaller) vent, you could trim out the center of the plexi-glass to provide adequate air flow for the new vents. The plexi-glass can be painted white or your desired color.
Old 02-10-2019, 06:40 PM   #5
Cramerrr,
The refrigerator Vent Covers are readily available on Amazon. Prices range from $32 - $39. They come with the Frame and the Vent Door cover. If your frame is in good shape then you only need to use the vent door. T
There are two brands - Dometic and Norcold. And they are both the same overall size of 21 1/2" x 13 3/4" - which INCLUDES the frame in that measurement. So the Vent Door itself would be 20" x 12" - (Just what you need).
If you have a Dometic frig in your Class B, then most likely the Vent Covers are Dometic. Or if a Norcold frig, then your covers are Norcolds. Just search "RV REFRIGERATOR VENT COVER" on Amazon and then check through the various choices. There is a smaller size vent cover, so make sure you choose the larger one that is the size you need.
Amazon has a lot of replacement parts for older RV's. I've bought the refrigerator vent covers and roof-top A/C plastic shroud covers from Amazon - as well as tons of other stuff for my older Class B and B+ RV's.
David
PS I tried to post photos but I don't know what the URL is or where to find it for the photos. Usually you can just double-click to download a photo
David
Now: 1998 Coachmen Starflyte FRB 21' Class B+
Formerly: 1996 Coachmen M19-RD GMC 19' Class B
TatraDog is offline   Reply With Quote
Old 02-15-2019, 07:20 PM   #6
I purchased some domestic replacements back In November and they did not fit the cut out even when I removed the frame. They are a few inches too big and they are more a rectangle shape vs having rounded corners.
Old 02-18-2019, 03:00 PM   #7
Check out the photos of the NORCOLD vent covers on Amazon. They look to have rounder corners that the Dometic. Maybe they are better. Is the frig in your RV a Norcold?
David
