Old 07-28-2020, 06:47 PM   #1
Default Installing Reverse Switch for a Sony Head unit.
00CHEVY200 POPULAR Has anybody put in a rearview camera in 00C200P RT? Actually, I'm suppose to attach the reverse switch from the Sony head unit to the "green" wire on the truck. I got the unit from Crutchfield and they said it was the green wire in the E7 socket on the 48 socket "convenience" center. Well, there are only 5 green wires (different shades), and I've tried them all, none of them turn the camera off and on. Yes, the camera works. Some of the wires have a current and turns the camera on. And I am clueless how to determine where the E7 socket is located. Anybody??? Ideas.
Morry is offline   Reply With Quote
Old 07-28-2020, 08:09 PM   #2
possible the circuit is only active when in reverse
if vehicle allows reverse gear selection with motor off, try again
mike
Old 07-28-2020, 09:12 PM   #3
Yes, that's the way it's supposed to work. You shift into reverse and the camera comes on.
Old 07-28-2020, 11:24 PM   #4
Default Reverse Camera wire
I got some new info from Crutchfield. They had a drawing that shows me exactly which wire to use. I'll let you know tomorrow if it does the trick!
