Old 06-23-2022, 09:55 PM   #1
manoverboard's Avatar
Default Help! RT water tank inlet plugs
Need help in finding replacement plastic plugs that insert into the inlet hole for the FW tanks. I have a 2010 RT 190Pop and the 2 plastic plugs (were orange or red) are deteriorating. They have to seal flat so the doors can close.
Anybody have an idea for replacements??
(I think they are 1 1/4" or 1 3/16")
....whatever....
manoverboard is offline   Reply With Quote
Old 06-23-2022, 11:37 PM   #2
This might fit your RT. It is 1 3/16 at the base and tapered so it is wider at the top and has a lip.
https://www.mobiliferv.ca/rv-parts/r...-hm-1206/6386/
Old 06-24-2022, 07:01 AM   #3
Assuming they are the same fill ports as my 2003, MOCAP Center Pull Tapered Plug: CP1.17/1.28RD1 will work - those are what I bought when I needed a replacement. At least it works on the back door - I don't have a fill port in the drivers door.
2003 Roadtrek 190 Popular
Gryphon is offline   Reply With Quote
Old 06-24-2022, 01:42 PM   #4
Thanks. Exactly what I’m looking for.
Also, thanks for helping a newbie with finding needed parts.
....whatever....
Old 06-24-2022, 10:55 PM   #5
I went to HD and got this. Other sizes are available.
https://www.homedepot.com/p/DANCO-1-...0225/206398653
Drilled a small hole and replaced existing, deteriorating plug.
2015 Roadtrek RS Adventurous
HubFlyer is offline   Reply With Quote
