Old 01-22-2019, 08:31 PM   #1
Default Dodge Ram Promaster battery part
Had to remove / replace my Dodge Ram Promaster engine battery recently for my 2016 Roadtrek Zion, and broke a small red plastic piece apparently designed to help hold a fuse box to the top of the battery over the positive terminal. This Youtube video displays the part in question at about 1:45 in:
Can anyone suggest where I might find a replacement part? (I have questioned several area Dodge parts depts to no avail.)
bwiseman2724 is offline   Reply With Quote
Old 01-23-2019, 02:50 AM   #2
You say Promaster, but the video is Promaster City. Two completely different animals. Which do you have?
Old 01-23-2019, 05:53 PM   #3
You're right, it is a Promaster City in the video. However, the part in question is identical...that small red plastic piece with 2 screws holding fuse box to top of battery.
Old 01-24-2019, 02:28 PM   #4
Try stevewhiteparts.com
Old 02-03-2019, 11:38 AM   #5
Default Pro master Battery Part
I just changed battery in the same vehicle type and went to the Ram dealer to find out what was important. Having done that, I also broke the red plastic piece. I was told that it is just used to keep that large connector stable and from moving around while underway. So I put the red piece in, adjusted it to do what it was supposed to by tightening it in the original configuration and have gone about business. I am not planning on getting a new plastic piece, although I may 3D print one in my classroom if I get the time.
DBarr is offline   Reply With Quote
battery, ram promaster
