Old 02-04-2019, 10:54 PM   #1
bigfelipe's Avatar
Default Brunton Seat Warmer
Picked up one of these from REI for a cold weather option to cut down on the need to run my furnace. I am hoping sleeping with it under my core will be an efficient way to stay warm. Says it will run more than a full night at 100°...
https://www.rei.com/rei-garage/produ...olt-xl-battery
What do you think? Compact and should come in handy for a number of cold weather uses...
bigfelipe is offline   Reply With Quote
Old 02-04-2019, 11:12 PM   #2
When I go on long hikes/camping in the winter I wear one of these around my core. It comes with a smaller battery but I carry a 20,000 mAh battery in my backpack for 8-10 hour comfort.
Uses bluetooth so heat settings can be changed from your smartphone.
ClassB4Me is offline   Reply With Quote
Old 02-04-2019, 11:16 PM   #3
bigfelipe's Avatar
Pretty neat. Haven't seen one of those...
Old 02-14-2019, 05:51 PM   #4
We use the Brunton golf cart seat warmers under our sleeping bags in the back of our RV.. They work great.
Ray B is offline   Reply With Quote
Old 02-14-2019, 10:56 PM   #5
bigfelipe's Avatar
That was exactly what I was thinking. Thanks.
Old 02-15-2019, 11:09 PM   #6
Designed for this purpose. The dial goes to seven. Setting it at one half of one is usually warm enough. Though is says "twin", two can share.
Old 02-15-2019, 11:21 PM   #7
bigfelipe's Avatar
Yes I've seen those and I hear they are great but that pulls off the 12v system in the RV. The Brunton warmer I bought uses a battery pack I can charge when driving to stretch my amp hours. It's enough to get through at least one night, probably two between charges. Not a huge deal but every little bit helps in a B with limited resources. I boondock pretty exclusively.
