Old 07-15-2020, 01:40 AM   #1
Default Best Swinging Bike Rack
Hi All,
Looking to mount 2 bikes for campground cruising. Needs to swing out of the way of our RoadTrek Adventurous back doors. Any good options out there?
Russell
Stovebags is offline   Reply With Quote
Old 07-15-2020, 01:56 AM   #2
welcome to the forums
there are many alternatives
we rented in Ireland and the rental had a bike hanger on the primary rear door ( with bike overhanging the other door)
I would probably favor a mount on the front of the van, adding a 2" receiver
good for those of us with rear door mounted spare tires
also allows you to see if something is loose
last trip an RV flew past us with swaying bikes on the rack... and a few minutes later we saw 1...then the other of their bikes on the highway
mike
Old 07-15-2020, 11:50 AM   #3
Check out the From She To Me YouTube channel. They have a Sprinter based PW Ascent with a swing-away bike rack that handles two Rad Mini E-bikes.
2018 Hymer Aktiv 2.0 (Ecotrek replaced)
LostInWoods is offline   Reply With Quote
Old 08-19-2020, 08:03 PM   #4
Try looking at the Kuat NV 2.0. you can add a swing arm. It is a two bike rack that you can also option up to 4. I have this rack and use it on my Jeep. We plan to move it to our Pleasueway Tofino when it arrives in a month or so. Good luck
Jim
Drjimh is offline   Reply With Quote
Old 08-20-2020, 12:18 PM   #5
Thanks - do you have the pivot arm yet? I'm not sure REI has them still.
Old 10-20-2020, 06:22 PM   #6
Nspekter's Avatar
I’ve been looking for a swing away adapter that has a high enough weight rating to carry my 200 lb.Vespa plus the rack. Thule’s is rated at 350 lbs. and might work but I would like one in the 500 lb. range. Has anyone seen one?
Nspekter is offline   Reply With Quote
