Old 03-08-2024, 12:47 AM   #1
Default Automatic Transfer Switch buzz
Hi
I have new Thor RV on a Ram 3500 Promaster.
When I am hooked up to shore power, there is a noticeable hum- buzzing sound, from the Southwire Model 41301 Automatic Transfer Switch.
Some have said "it's normal with a newer model" and "no, it shouldn't be doing that."
Does your Automatic Transfer Switch hum -buzz?
Thank you.
Dave-DJ is offline   Reply With Quote
Old 03-09-2024, 03:50 PM   #2
Kinda hard to tell without actually being there and hearing it. I would check the transfer switch's internal contacts and connections. Due note if the contactors get warm/hot with a good size electrical load.
Old 03-09-2024, 09:30 PM   #3
mloganusda's Avatar
Never noticed my transfer switch made a noise. I would check your internal wire connectors to make sure they are tight, as fires have been know to start because of loose connections heating up.
Old 03-09-2024, 09:37 PM   #4
My guess would be 60hz hum from the internal relay coil. Check to see that the relay is securely mounted.
Old 03-18-2024, 05:46 PM   #5
Hi,
You are correct coil buzz. Found only one maker uses DC coils, that do not buzz.
Ordered a ESCO LPT30BRD 30 Amp 120 Volts AC Automatic Transfer Switch with 120V DC coils.
Should be quiet.
Thank you.
