Old 10-08-2007, 02:39 AM   #1
Default Airlift air springs
I must say that my new airsprings really helped to make the towing easier. Just got back from Kansas and towing the 24 ft enclosed trailer and car was a lot easier. Definitely increased stability when trucks pass and crosswinds blow.
If you have a lot of tongue weight then this will definitely help.
Just an FYI,
Jim, Roadtrek 2004/Cnevy 210 PSE
autoxgod is offline   Reply With Quote
Old 10-27-2007, 08:57 PM   #2
denman's Avatar
I found the same with my Dodge Cummins. I have a heavy steel deck and had to carry a dead VW Jetta from Winnepeg to Edmonton. When I was loaded the rear was down a bit, even on HD rear springs. About 90psi in the air overloads put it just right and it rode fine.
1988 ChevyVan30 with "Escaper" camper mod,
1979 35' 5th Wheel "Cobra" travel trailer,
1993 Dodge Cummins Turbo Diesel,
1980 Honda GoldWing,
Trend: "all old like me! "
denman is offline   Reply With Quote
