Old 11-13-2013, 12:09 AM   #1
Default Where is the fuel pump and the EVAP canister located at? 1997 Rialta 6V
My fuel pressure is reading 45 psi, and there's also a very strong oddor of gas coming out when I turned off the car.
I was getting about 10 mpg. Increased now to just 12.5 mpg (As it's pretty annoying since I see everybody else is getting between 18-22 mpg) after I replaced the following:
EGR valve and connecting vacuum hoses
Fuel pressure regulator connecting vacuum hoses
Transmission wire harness
Transmission valve body assembly
Transmission oil change with gasket and filter
Spark Plugs
Air filter
Coach Filter
Oil change
Now the car is surging, some times shutting off completely, the iddle some times drops down, etc.
I need to replace the fuel pump and most likely the EVAP canister, can anyone tell me where is it located and any tips on how to do it efficiently?
Karlajustme is offline   Reply With Quote
Old 07-24-2018, 06:06 PM   #2
Spark Plugs
Air filter
Coach Filter
Oil change
Hello Karla, Did you ever figure your issue out?
Thank you,
Charles
TheRealRobinsons is offline   Reply With Quote
Old 07-25-2018, 10:35 PM   #3
Bruceper's Avatar
The post you replied to is five years old. You're likely not getting an answer.
