Old 04-15-2014, 06:21 PM   #1
Default Wanted Railta
I am looking for a newer Rialta with low miles. I only have $15,000 to spend.
cabin129 is offline   Reply With Quote
Old 04-19-2014, 06:27 PM   #2
mloganusda's Avatar
Look under thye SWAP ssection and you will find serveral Rialtas posted for sale. The last Rialta made was in 2005 and is now 9 years old. To find a low milage R for $15K I douth that you will find one. You may get lucky and find an R for $15K but will be high milage and rusted out. Check Craigslist all around the country for an R.
Old 04-30-2014, 07:27 PM   #3
mloganusda's Avatar
We are considering selling our 1997 Rialta RD. It has the VR6 engine and all the accessories for that year.
John Huntington's 97 RD VIN: WV3AH8705VH117080
huntinjf@... Stored in our son's barn N of Hamilton, OH
Two volume set Bentley manuals
CD of Bentley manuals
New 2,000 lb rated Audi/VW rear wheel bearings installed 2014
Monroe shocks front 37195, rear 555041 (Jul 2013)
New Trimark coach door lock (2013) 2 keys each for latch and deadbolt
New seal coach door (top and part of side) Winnebago # 11153603000
Coach batteries new Energizer 27dcn (8/2010)
Cab battery type 42 Interstate (2013)
New cab air filter (Dec 2012)
Cooler kit Makco (4921-K) for transmission: installed by Dr. Rialta
Bypass kit and wider hose clamps also installed by Dr. Rialta (Duane)
New spark plugs NGK i rd and wire set (Jul 2013)
Fuel shut off valve for Generac
Transmission oil change (Jul 2012) Import ATF fluid
Coolant system tune up (Jul 2012)
Replace AC compressor & clutch (Jul 2012)
New serpentine belt (2012)
Inspect rear axle for cracks while on lift none found (Sep 2013)
New rear brake rotors and pads (Mar 2014)
Tires Goodyear Wrangler 215-75-15" on all four wheels (2095 LBS @ 65psi) (about 4 years old)
DVD/TV flat screen TV mounted on a post on driver's side dinette (2013)
Front seat covers (note the Lakewood fabric is subject to wear...no tears)
LED interior lights in coach (2013)
Power plug hatch mounted in rear door (2013)
New ECH solenoid (2010)
Cabin filter replaced (Nov 2012)
New gas cap 2013 (have not had new keys made to match originals)
Old cap had seal refreshed and code was deleted on Scan Gauge II
Ice maker (110v) makes ice in 12-15 minutes (2013)
Dometic worked when purchased but I purchased a Dometic compressor freezer/fridge and use that.
On the drive through the Allegheny, Adirondacks and Green Mountains and return (visit the NH Rally) (about 2000K) the calculated gas mileage was 17.4 mpg.
On a drive to SW MO, then on the Brownsville, TX to Duane's and return mileage was 17.5 mpg. On drive and return to Ellisburg. MS ('uplifting event') mileage was 16.8 mpg. I drive at the speed of the 'big boys' (60-65 mph).
The last time it was driven there were no 'check lights'. Many tools, manuals, cooking utensils, etc will be included since we are considering ending our RV travels. The RV's we've owned were: Fan, Airstream Trade Wind, 2 Scamps, 19' class C, a 27' Jamboree class C, A Toyota Sunrader (fiberglass coach), 95 Rialta RD and finally the 97RD.
The unit looks nice and drives very well. We have been engaged owners, caring for reliability and safety of the Rialta. It is priced at $17,500. It has been driven about 87,461 miles. A Carfax is available.
I'd like a Rialta club member to purchase it. I can be reached at (513) 524-7730 or at huntinjf@....
I will provide photos when the weather is cooperative.
