Old 01-03-2015, 03:43 PM   #1
Default Turn signal/cruise control switch
Hello,
I need help. I have a 1995 Rialta which needs a turn signal switch with the cruise control. They say that it is no longer available anywhere. The part number is 701953513B01C.
The clicking of the turn signal will not stop at all. The relay was checked. The mechanic said that I need this part. Help! I don't want to give up cruise control.
Xinema is offline   Reply With Quote
Old 01-04-2015, 11:33 AM   #2
For an exact replacement, your only choice now is a junk yard. I don't know if the newer one will fit and/or work. The p/n on it is 7D0953513C 01C. Best price I found was at http://tinyurl.com/pkfg6g4  A little expensive just to see if it will work. The 01C at the end is the color code, so you might try searching without it, also on the original.
Duane
TXPigeon is offline   Reply With Quote
Old 01-04-2015, 03:12 PM   #3
mloganusda's Avatar
Another place you can try for used part is Mobility RV, which has a few Rialtas for parts.
http://www.winnebagoparts.com
