Old 01-25-2015, 07:18 PM   #1
Default trying to find the OBD port on 1996 Rialta that has a 1995 engine
I have a 1996 Eurovan with a 1995 engine ( 45 K miles on it ).
I'm trying to find the OBD port so I can attach a Scangage for Transmission Temps
Can you help please?
Thanks
Chuck
Chuck711 is offline   Reply With Quote
Old 01-27-2015, 02:38 AM   #2
tthere is no obd port on the 96.. U do have a 2 wire computor hook up in the fuss area on driver side inde the rialta.. believe me I searched every aspect to find one and VW finaly told me there isnt one..
herbert is offline   Reply With Quote
Old 02-22-2015, 06:46 PM   #3
bigdan's Avatar
yiu need a little wire adapter ...
any Vagcom specialist will sell you one ....
be advise that only the scan gauge II can handle this task ....
the chinese version doesnt read the first OBD versions
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 02-23-2015, 10:32 AM   #4
The Scangauge II will not work on the OBD I units, even with the adapter. You'd need VCDS to read the computers. You can also find information on the web on how to read the codes using the Blink Codes.
Duane
TXPigeon is offline   Reply With Quote
