Old 11-14-2011, 01:32 AM   #1
Default transmission dipstick
am trying to install transmission dipstick on newer model rialta which did not have one originally. I can't locate the assembly anywhere. Any thoughts?
mark malley is offline   Reply With Quote
Old 11-14-2011, 10:52 AM   #2
rem
Did you contact a VW dealer. A Euro van stick should fit as long as eng. are the same. How about a salvage yard. Or give http://www.Rockauto.com a try
Rem
rem is offline   Reply With Quote
Old 12-12-2011, 08:43 PM   #3
depending on which model and year, the transmission is sealed which is why there is no dipstick. Dealer recommends change every 90-100K miles but if you read the forum notes from Rialta owners, you may wish to change more frequently, every 40K....I changed mine at Aamco and it cost $215 and has national warranty.
pastorjon is offline   Reply With Quote
Old 12-27-2011, 09:54 PM   #4
Check the Rialta tech site at Yahoo Groups. Most there recommend every 10-20,000 miles for transmission fluid change depending on type of driving. Fluid breaks down when overheated (mtn. driving, summer driving, etc.) We change after each major trip (10K).
C.Reese
98 RC Twin
csreese is offline   Reply With Quote
Old 03-26-2012, 05:32 AM   #5
The dipstick kit is a waste of time. I took the dipstick out and installed a VW seal cap on the filler tube. Once the tranny is filled the proper way, and sealed, and there are no leaks, there is no need to ever add oil untill the oil is changed. Rialta has a CD out that tell you how to change the oil and filter, yourself. It is very easy and costs about $75.00. All of the VW Eurovan parts can be bought on line at partsgeek.com, at a very low price. The correct oil level is not accurate with a dip stick but is determined by a overflow pipe on the inside of the tranny oil pan. There is a small allen seal screw on the under side of the oil pan that lets oil run out when the proper leval is reached and the oil is hot. That is the proper level and method.
mraggent is offline   Reply With Quote
