Old 11-30-2015, 09:09 PM   #1
Default Transmission Control Module
I have a 2000 Rialta that I believe the TCM may be damaged due to water infiltration at the windshield. I've read on other entries that I could find this part at eeuroparts.com. It's part #01P927733BC or CM not sure which is correct. I think I read that Winnebago modified the shift points based on the increased weight. Can anyone verify if this is correct. If so, where I could find one? This is my first step in determining if I need a new transmission or not. Thanks for input.
Harve is offline   Reply With Quote
