Tires on ice and snow
Probably the best advice I would give for driving on ice/snow is DON'T.
The Vanco tires that were original equipment have very little traction in slippery conditions, including sand. You can improve it quite a bit by getting some better tires. Nokian has some WR C Van tires that are rated for snow and have better grip. For the short term, you could buy some cable type chains for help.
Even the best tires won't fix all the problems. The rear tires have a wider track than the front, so you have to create 4 tracks in the snow instead of 2 like most vehicles. That creates more resistance and less traction.
Take it slow and best of luck getting to a place where it won't be a concern for awhile.
Duane
