Old 04-04-2012, 03:11 PM   #1
Default Starter mounting bolts torque?
My wife Nancy and I own a 2001 Rialta with a 2000 Eurovan. I am replacing the starter and would like to confirm the starter mounting bolt torque. The information I have is from http://www.torkspec.com and it lists 18 ft-lbs for all VR6 engines. Considering the amount of force it took to remove those bolts, it seems a bit light. If anyone can confirm or correct that specification, I would appreciate it very much.
Thank you, Guy Russell
guyprussell is offline   Reply With Quote
Old 04-04-2012, 04:05 PM   #2
rem
I replaced the starter on my 2005 last fall. I torqued it to specks & the added a little more. Did two trips & everything ok
rem is offline   Reply With Quote
Old 04-04-2012, 04:05 PM   #3
rem
Old 04-04-2012, 06:41 PM   #4
Thanks for your reply!
Guy
