Old 03-09-2012, 04:09 AM   #1
Default SIDE DOOR LOCK
The side door passage lock of my unit cannot be locked from the outside (the deadbolt works fine). The key just won't turn due to the mechanism that locks it from the inside. Has anyone ever had this problem and repaired it?
Thanks,
Harry
mchughhr is offline   Reply With Quote
Old 03-24-2012, 08:40 PM   #2
rem
Harry, Had a problem with mine also. I removed the inside panel & bent the rod which controls the lock. Everything works fine now. It's only four screws to be removed.18
rem is offline   Reply With Quote
