Old 12-14-2009, 12:45 AM   #1
Default Shower pump sump (1994)
Hi! We have a broken shower sump pump (early warning was wet area in front of fridge and then progressively becoming soaking). We hope someone might know what is the best way to change a shower sump pump. Thanks!
Gabby is offline   Reply With Quote
Old 01-04-2010, 06:41 PM   #2
Have you checked the circut breakers?
Frank
Frank W is offline   Reply With Quote
Old 01-04-2010, 07:00 PM   #3
I see many campers have problems with these shower drains. They are so small,they clog up easily.
We never use the shower. Most campgrounds have hot showers now.
Old 08-10-2010, 08:04 PM   #4
Gabby said:Hi! We have a broken shower sump pump (early warning was wet area in front of fridge and then progressively becoming soaking). We hope someone might know what is the best way to change a shower sump pump. Thanks!
We replaced the pump on our shower. We have used it extensively since then. It is necessary to clean the little filter before and after your shower. They tend to clog easily.
Marj
papaboy is offline   Reply With Quote
