Old 03-15-2013, 01:08 AM   #1
Default Rialta frame extensions for trailer hitch
We have purchased a used Rialta hitch for our 2003 QD. However the main frame rails do not extend far enough backward to meet up with the two ends of the trailer hitch. When thecenter piece is bolted on, the ends of the hitch end up about 6" rearward of the ends of the frame. Is there and w=extension that bolts to the ends of the frame? Looks like there used to be one on each side. Any help ?
Bob and Dedra is offline   Reply With Quote
Old 03-16-2013, 03:45 PM   #2
mloganusda's Avatar
Default Need frame extensions for trailer hitch
On my 04' HD the trailer hitch is like and E but without the top and bottom extensions. The main bar bolts to the side frames and the receiving tube extends back to an angle plate that has two bolts into the cross member. There is no conection above the middle receiver tube to any frame. My receiving tube is a 1 1/2" tube and I have to have an adaptor to use a 2" carrier. Remember, the Rialta has the european tail light system where the stop and turn signals are seperate. You need a 3 wire to 2 wire adaptor to be able to use an american trailer light system.
