Old 06-17-2014, 03:30 PM   #1
Default Replacement toilet taller
Replacing the original toilet. Called Thetford and they gave me wrong advice. When I contacted their customer service, the person there was very rude and basically said I am stuck with the Bravura (i am out $166 and it is not a direct replacement). Horrible customer service. Having said that, can anyone recommend a non-Thetford toillet that would fit in my 2001? It needs to be taller, too. Thank you.
sierra is offline   Reply With Quote
Old 06-19-2014, 07:17 AM   #2
You could look at http://www.rvpartscountry.com/RVToilets to see what's available. They show dimensions on the ones I looked at so you can tell if it fits. I know the Thetford Aqua Magic V works, but since you don't want one of theirs, Dometic is about the only choice.
Duane
TXPigeon is offline   Reply With Quote
Old 08-21-2014, 08:38 PM   #3
If it is taller you will not be able to put the tray and sink down.
Neisman is offline   Reply With Quote
