Old 08-22-2012, 11:48 PM   #1
Default replaceing the Audiovox VHS player with a 12vdc DVD player - anyone done this?
Would like to upgrade the built in 9" TV and the VHS player (2002 QD) and use the shrouds if possible. Has anybody found a way to do this?
rsbagley is offline   Reply With Quote
Old 08-11-2013, 09:21 PM   #2
I took the 9" tv out today. Looking at the casing, I think I can glue on a top, add a cabinet door and have a place to store maps. I bought a 15" LED tv w/dvd player I am going to mount in the back (?) next to the table on the back shelf.
I haven't taken the VCR out yet, I'm hoping there is no hole, like in the front...
I will let you know how it comes out.
Rick
rickgudnason is offline   Reply With Quote
Old 08-11-2013, 09:47 PM   #3
when you remove the shroud there is a relatively small hole left where the cables and power supply come out.
Not hard to cover.
Bob and Dedra is offline   Reply With Quote
Old 04-10-2016, 11:46 PM   #4
Rick
Did you remove the VCR in the back yet? If so, did you remove the casing? I think this is what you mean by shroud? I, too, have installed a smaller flat screen tv and would like to replace the VCR with a DVD player. Will it play to a TV connected to the Rear Cable Outlet?
stephanietwest is offline   Reply With Quote
Old 04-10-2016, 11:48 PM   #5
Default Did you remove the VCR?
Not hard to cover.
